KDL-43W805C - Google Play Store Empty?
SOLVED
pantalej
Explorer
Hello all,
I have a problem with the Google Play Store. When I open the application its Home screen flickers with what is supposed to be shown, you know... apps and such, and then it goes empty - there is nothing shown. As seen here: undefined
Anyone have the same problem? Or better yet a solution?
57 REPLIES 57
tercopettinato
Explorer
OMG, changed to Wi-Fi and worked again. But there are not all the apps in there.. Missing PLEX 😞
profile.country.RO.title
alexw85
Member
STILL EMPTY
Axel_ost
Explorer
Well, now I have in the Sony Select app a category in Hungarian (I think)...and google translate says it means "continue to apply for workers" :laughing:
Google play store gives a server error although I am on wifi.
EDIT: A factory reset solved the problem. Now Google play works and it updates the core apps. I hope this will not revert once I turn off the TV :slight_smile:
tercopettinato
Explorer
Well I needed Google store for Plex, but the app is missing in my "modified" :slight_smile: store. So I downloaded it manually and istalled it over explorer. The server error and the "modified" google play store appeared after the last update. 😞
alexw85
Member
FIXED WITH LATEST GOOGLE PLAY STORE 6.3.6.1.B
Anonymous
Not applicable
Thanks for confirming - can any others confirm too?
alexw85
Member
Sorry for the misstype. The correct version of latest google play store is 6.3.16.B-xhdpi.
relliKW
Explorer
Yes. Everything works fine now. :slight_smile:
