my Sony KD-65X75K no longer turn on
Kadbraun65
1 ODPOWIEDŹ 1
TheGOAT
@Kadbraun65 It sounds silly but try to use the power button on the TV cause maybe the issue is with the remote, if not check the fuses of the outlet or try another source. Last thing you can do forced factory reset to see if the TV will respond or not: https://www.sony.co.uk/electronics/support/articles/00274122?link-header
