- Press the HOME button
- Scroll down to Settings
- In the Personal section select Parental Lock (Broadcast)
- Enter the Master PIN (9999)
- Select Change PIN Code and change it to your desired PIN.
Cheers
I have a Sony KD-43X830XC television. I have not set up any parental control on it as we do not have children.
When I tried to go onto the Demand5 iplayer to watch a recording last night, I was asked for my parental password. I do not have one as I know it.
Anyone be able to throw some light on this?
I tried the suggested 9999 in the Sony handbook to unlock but that doesn't work.
Thanks
Paul
Hi there
Try resetting the pin via this method:
Cheers
