Προβλημα με τηλεοραση
profile.country.GR.title
Korinamu
Neues Mitglied
Η τηλεόραση μου sony experia σβήνει ξαφνικά και δεν ανταποκρίνεται. Πρέπει να τη βγάλω από την πρίζα για να ξαναλειτουργήσει..
1 ANTWORT 1
Mick_D
Moderator
HI @Korinamu, welcome to the Community.
As this is an English-speaking forum, you will probably struggle to get any replies in your native language. Could I suggest using Google translate?
I believe you were asking about restarting your TV, and this would be a good first step if you are experiencing problems.
Switch off the TV, unplug at the wall, wait 30 seconds, then plug in and power on. This should reset the TV.
Best wishes
Mick
