Screen settings not available on HDMI1.
Andy181
Explorer
We recently purchased a KD43XG8096 and discovered that with my Freesat HD receiver plugged into HDMI1, most of the screen size/aspect settings are greyed out. I only discovered this after I'd carefully labelled my 3 HDMI sources. I had to move the Freesat receiver from HDMI1 to HDMI2 before I could change the 4:3 default setting from wide to normal.  I can't find any overscan toggle either. I really like the set, but it needs its software tweaking!
1 REPLY 1
profile.country.IT.title
rooobb
Via HDMI it is up to the connected device to change the aspect, not the tv. If the tv receive a wide picture it will display it accordingly, if it receives a 4:3 it will do so
