KD-55XH 9505 cannot switch off with Sky Q remote,set up with Bravia Sync,exact model number selected on Sky Q box ,done power downs.Any help please.
Sky Q does not turn off any TV using HDMI Control (Bravia Sync/CEC/etc.). That function is not included with Sky Q.
Assuming that the remote has been correctly paired with your TV then hold down the Sky Q remote power button for 2-3 seconds and that should put the TV into standby. So it requires two presses on the Sky Q remote power button. Short one for Sky Q and longer one for the TV..
Hey @standishman65, this issue is related to the Sky Q box. Have you tested the Bravia Sync features with the Sony remote? Does it turn On/Off both devices? As this feature is mainly allowing you to use your TV's remote to control other Bravia Sync compatible devices.
Thanks for this.
I have just upgraded our Bravia and was having issues with the restart problem.
Bang on 3 seconds and off it goes.
Happy wife Happy life!!
Thanks Elodin
Still getting my head around the myriad of settings and getting my soundbar to play nice.....
Double post!
What's wrong with the soundbar itself? Is it a Sony SB? Or not?
Hi SkyNet
Its a Sony soundbar. Just a few issues regards menus etc. Think I'm there now. It was a lag in lip sync which I eventually found. Typical bloke in that connect it all up and then read a manual when something isn't right. Or that's what the wife says but what do they know? LOL
Wives know:-
Switch it off and switch it on again.
Reboot it.
Reset it.
Go in the other room and watch the non-Sony TV there 😛
