Hi, is it normal that sometime changing between apps the TV turns off? It only happened once when exit the video app to live TV and I press it back to the tv button and the back button very fast and it was when turns off . It has happened to me once in a week that I have it ...
Thank you.
Hi theflyingdove,
Welcome to the community.
It might be worth doing a reset or factory data reset on your AF8. You can find instructions here.
Thanks,
Pascale
