Sony Bravia A95K hissing sound when the Acoustic Center Sync is plugged-in
profile.country.IE.title
clodola
New
Hi
I just purchased a Sony Theater Bar 9 , when I plug in the 3.5mm jack to avail of the Acoustic Center Sync, I have a terrible hissing noise
From reading online , it appears to be a motherboard replacement ?
Anybody have any solutions?
thanks
1 REPLY 1
Lord_viridis
You can try a different 3.5mm cable as some cables can have hiss if even one pole is not connecting well, however if the bar 9 has just been purchased, and you're using the provided cables, I would recommend going back to retailer for a replacement so soon after purchase.
If still within 30 days, you can ask for replacement if a fault develops.
After 30 days they can ask that it be repaired instead.
