Sony HTA9M2 BRAVIA 4.1.4 Bravia Theatre Quad/ Apple Homekit support + SASW5
mohsen0
Hi, are there any plans to add support for Homekit integration?
so we can control the volume and other features remotely using home kit,
it is really a missing feature when you want to enable the night mode after a certain time every night so your neighbours do not complain about the sound. or set the volume too.
This is an expensive flagship product, it is really a missing feature. I wish using the Bravia Connect I just enrol the system into Apple Home Kit (or maybe Google Home for other users)
1 ODPOWIEDŹ 1
TheGOAT
@mohsen0 It supports AirPlay by the way you can utilize that: https://helpguide.sony.net/ht/2080/v1/en/contents/042_Using_AirPlay.html
