- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony kd-48a9 LAN port max mbps?
I have a Sony oled Kd48a9 and we have recently installed some ports and access points in the house. We have a port that goes from the router, to a switch and then to the port. So basically hardwired. The idea was so that I could use an ethernet for the TV for stability. We get 200 mbps but when I do a speedtest on Netflix it shows I am getting 50 to 60 mbps. I switch to wireless and then do same check and get between 120 and 130. So why is this happening? Is their a limit on the LAN port in the TV? 50 to 60 is still sufficient but surely wired should be better speed than wireless. Ethernet cable is Cat6 and yes I have checked the port and I get fast speed with a laptop for example. Its definitely something to do with the LAN in the TV.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Any TV on the market spots just 100 Mbps Lan port so the maximum speed available on WiFi can be higher. I still prefer the wired one that for the most use of a TV is more than enough (netflix i.e. uses maximum 16 Mbps)
