Partilhe a sua experiência!
Hi, can anyone give any advice? I have this tv which is absolutely superb, but I am having a few issues getting the colour set properly. The RED seems to be overpowering all the other colours. On standard definition it is a lot worse than Hi Def. I have turned the red gamma down, but the red colour is still too strong. Has anyone got any settings they can give?
The general settings I use are here (currently 4th post from the end of thread)
If you have altered gamma and other advanced settings (and haven't noted down the original settings first) then I would recommend a factory reset and start again.
Also follow this guide and use the test chart available in the link:
