отмена
Отображаются результаты для
Вместо этого искать
Вы имели в виду:
sony KD 49XF 9005
profile.country.HR.title
materak
Исследователь
sony KD 49XF 9005
 i have a problem with streaming from you tube because  i havent suround sound
23 ОТВЕТ 23
profile.country.RO.title
snapisrl
Участник
my tv 55fx9005
snapisrl
Участник
my remote tx100e working fine before oreo 8.
working perfect with android native android 7.
after update android 8 oreo not function 4-5 butons and touchpad zone display with cursors inverse ????
Killermio24
Исследователь
After latest update my TV has stop supporting DTS sound via X1X and musiccast surround sound system
Help.
profile.country.GR.title
panlask
Участник
I put the update and things are like that:
  • Most MKVs play with 5.1 sound properly with the built in player
  • Some still have issues loading (probably a sound or other format issue)
  • Those that do not load, play very well in Kodi
  • But Kodi plays only 2 channels no matter what (even with pass through on)!!
  • Youtube doesn't play 5.1 but I believe it wouldn't suport anyway
  • Netflix etc. I don't have so far
So, this is a partial solution to the previous update issues.
