Hei,anyone has same problem?Netflix is only black screen,no nothing.Use to work perfectly.Works in the computer still.
Hi there
It looks like there was a brief period when Netflix was down - as ive just loaded it on my TV (KD-55XD8577) and recieved an error message. Im please to confirm that its now working again (for me). If your still having troubles, try a soft reboot of the TV - press and hold the power button on the remote control for 6-10 seconds and the tv will reboot.
Cheers
Hi there
Cheers
