Sony KDL-43W807C
juliehobbs
Sony KDL-43W807C
Just purchased the Sony KDL-43W807C Smart 3D Full HD TV  to replace my old Sony.
I do not really need to use the internet and I have a you view box, there have been updates popping up which are a bit of nuisance as you cannot use the tv whilst they are updating.  Could anyone tell me how I can disconnect my hub from this tv?  if in the future I decide to use it can it be installed later?
many thanks
10 ODPOW. 10
Anonymous
Nie dotyczy
Hi there
To turn OFF automatic updates:
  1. Press the [HELP] button on the remote control (or you can press [HOME] and scroll down to 'Help'
  2. Scroll down to 'System software update' and press [OK]
  3. Scroll down to 'Automatic software download' and press [OK]
  4. Select 'Off' and press [OK]
  5. Done - return to TV.
Cheers
