Which one what the best SONY TV 43inch, Yes has is 4K, SMART, ANDROID and has a DIRECT LED? Koji je najbolji SONY TV, a da ima 4K, SMART, ANDROID i DIRECT LED?
Hi @dealsta
The best is subjective and everyone has an opinion. However if you mean which TV have the latest fast components then Sony’s numbering system tells you. For example XH85 appears to be the latest (when available).
1. X = 4K
2 H=2020, G=2019, F=2018
3. 8 = Android, 7 = Linux (not always true for all years)
4. 5, this is simple, the higher the number the better the specification.
5. You should compare specs, The newer the TV doesn’t make it better, only careful comparison will tell you.
6. If you are interested in Android then make sure that Pie is available but don’t be surprised if it is not supported on small TVs.
I visited the site you posted, and got a response for a answer for 43inch TV that they are the best of the XH85 series in that size. i ask you when these models will arrive in the sovereign neutral republic of Serbia?
@dealsta wrote:I visited the site you posted, and got a response for a answer for 43inch TV that they are the best of the XH85 series in that size. i ask you when these models will arrive in the sovereign neutral republic of Serbia?
Hi @dealsta Sorry, this is a user community (not Sony) so nobody knows when it will be available.
