Soundbar - XF9005 ?
mikegunnill
Neues Mitglied
Soundbar - XF9005 ?
I have a XF9005 with a Sony Soundbar CT380. I understand the soundbar is not working correctly through the Ark socket.  I need to replace this unit and note the same model isn't avavailable in the UK.  I have seen the CT290 soundbar. Would this match/be compatible?
Grateful for assistance, thank you
Mike
2 ANTWORTEN 2
royabrown
Enthusiast
YouView Superuser, but not an employee of YouView, nor retained by them for this purpose. It's purely me speaking
mikegunnill
Neues Mitglied
Thank you for your reply.
I note the sound bar does have lip-sync problems. If using an opitical cable as well will this help?
Thx
Mike
