which operating system have KDL-32WD755.
profile.country.HR.title
Hazl113
Explorer
Nowhere I can find the information which operating system have my new TV KDL-32WD755.
Does anyone know this information?
3 REPLIES 3
LightFoot
Specialist
Hi @Hazl113   Linux.
It shares the same software with the entire WD75 range. See applicable models. For example see the specifications for KDL-32WD754.
https://www.sony.co.uk/electronics/support/lcd-tvs-wd75x_w75xd-series/kdl-32wd755/downloads/00016216
https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs/kdl-32wd754/specifications
Hazl113
Explorer
Yes, I know that. But nowhere does it say what operating system it in TV. Why doesn't it say that? Is Linux OK?
LightFoot
Specialist
Hi @Hazl113
It shows the operating system in the KDL-32WD754 specifications (below) which are the same for the KDL-32WD755. Sony use Linux in their entry level TVs. The "smart" features are what you see is all you get unlike the Android TVs which have the Google Play Store. On Android TVs it says Operating System - Android.
Note the user support community for your TV is https://community.sony.co.uk/t5/other-tvs/bd-p/tv_en_1
