Why is there no setting option to "disable" Dolby Vision? (XG9005)
stormyuk
On the XG9005 some programmes (especially on netflix) actually look worse on the XG with Dolby Vision than they do on the XE9005 with HDR10. Sabrina (which I have discussed in another thread) is one of those programmes. Its not great on either TV to be honest in HDR as its just too dark, its actually more watchable in SDR. Dolby Vision on the XG actually makes things much, much worse because the XG exhibits horrendous blooming in the black bars on this programme, its not a general issue with HDR content but Sabrina almost seems to turn light zones on and off on the FALD, completely at odds with what is being displayed on the screen.
Why in their wisdom did Sony not add a setting to "disable DV" like you can with standard HDR. Its a clear example of where a switch between No HDR, HDR10 or DV would allow the user to view the content in the way they prefer.
Netflix seems to if you have a premium package and a DV set, you get DV if the programme offers it. So the only way around it is to use an external device without DV or downgrade the Netflix package.
15 ODPOW. 15
profile.country.HR.title
kinggo01
can't you just disable it under picture options while watching some HDR? It should stay like that after.
Tagi (1)
profile.country.GR.title
eteokritis
No i cannot if it is Dolby vision . The option is disabled In other hdr content it can . ,!
stormyuk
No unfortunately not. There is no way to disable it.
eteokritis
The answer from my country Sony support is that there is no mulfunction in the tv so they close the case!
Joe_Dohn
Specjalista
I passed on your feedback to Sony, hopefully this can be added in a future update!
Fredducpaw
Same here. Just had a lengthy chat with tech support and they tell me it's the apps not the TV. Yet I can turn off DV on the XBOX using all the same apps. They are telling me to shove it and it's not their fault, it's Netflix, Disney +, etc
