xe9305 tv sound is good at 23 on Freeview but has to be set at 55 on Netflix and then has high base
michaelsimac
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Anonymous
Nie dotyczy
Hi Michaelsimac,
You can press on HOME- settings- storage and reset- internal shared storage- cashed data.
9 ODPOW. 9
Anonymous
Nie dotyczy
Hi Michaelsimac,
Was it always like this? and we are talking about built in Netflix, correct?
michaelsimac
Yes it has always been like this and yes Netflix is built in,
Joe_Dohn
Specjalista
Have you tried clearing the cached data for the TV or updating the software for example?
michaelsimac
Hi software is the latest but I dont know what cache is or how to clear it. m
Anonymous
Nie dotyczy
Hi Michaelsimac,
michaelsimac
thanks for help  m
Joe_Dohn
Specjalista
@michaelsimac Has this solved it for you?
michaelsimac
no still the same!!  m
Joe_Dohn
Specjalista
Double-check that you have the latest v6.7140 version, then go for a factory reset.
Just to be sure, I'm assuming when you say "Freeview" you're referring to having the aerial connected to the back of the TV and not a Freeview box, is that right?
- JD
