Please help me to improve my Sony Xperia C3, Thanks
Sesth
Visitor
Tags (1)
3 REPLIES 3
Jonas
Master
Hi @Sesth, welcome to our forum!
What do you need assistance with? Is the device for example, slow and not as fast as it used to be?
A good place to start is making sure that you have some free storage on the device. We recommend that you have at least 5% of the internal storage free so apps can save the data that they need and for all functions to work properly.
Please do elaborate a bit! Slightly_smiling_Face
aditaapate
Visitor
my device not power on sony xepria screen on and off that is coming on screen and on offthat is coming on screen and on off
Jonas
Master
Hi @aditaapate, sorry to hear that. Slightly_frowning_Face
Have you tried removing the SIM and/or SD card(s) from the device and powered it on again? If you haven't done that, please do.
If there is no change after removing the card(s), perform a software repair using Xperia Companion.
This will delete all data stored on the internal storage and a backup is not possible.
Let me know if that helps!
