- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
Disponível novo firmware para câmeras NEX...versão 0.4...:smileyhappy:
Cumprimentos
Решено! Перейти к решению.
Утвержденные решения
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
This utility upgrades the NEX-5 firmware to version 04, and provides the following benefits:
- Addition of the [Picture Effect] function.
- Addition of the [Peaking] function in manual focus mode.
Benefits provided by previous upgrade program (Ver.03) and included in version 04.
- Addition of the function to customize soft keys.
It is now possible to customise the functions of two soft keys mounted on the camera's rear panel. - Addition of the [Menu start] function.
When ‘Menu’ is selected, there is now the option to display either the main menu screen or the last parameter set. - Improvement of the operability of the [MF Assist] function
An enlarged image portion can now be displayed on screen with user-selectable duration while in MF (Manual Focus) Assist mode. MF Assist operation has also been improved. - Improvement of the operability of menu item selection
The menu operation has been simplified. - Maintaining the aperture setting in the movie recording mode
HD video can now be shot while maintaining a constant aperture setting. - Support for the autofocus function with A-mount lenses
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Bom dia,
Tira-me só duas dúvidas. Comprei uma NEX 3 à 15 dias, se actualizar a versão 0.4 esta trás incluidas as anteriores ou tenho que as actualizar uma a uma? A outra é como uso as definições em Português existe algum problema neste update? Pois pareceu-me que este é só em inglês.
Cumps
Paulo
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Caro Paulo,
Bem-vindo ao forum da Sony...As actualizações acrescentam "algo" ao já existente pelo que não necessita de fazer mais nada...
Para proceder a esta actualização:
Confirmar a versão do firmware da sua câmara
Siga as instruções abaixo para verificar a versão do firmware da sua câmara.
Se a versão do firmware for a Ver.04 ou posterior, a actualização não é necessária.
- Seleccione Menu--> Setup [Configuração]--> Version [Versão] na câmara.
- A versão do firmware é apresentada da forma ilustrada abaixo.
Produtos suportados
- NEX-3 com firmware Ver.01., Ver.02. ou Ver.03.
Aperfeiçoamentos
Este utilitário actualiza o firmware da NEX-3 para a versão 04 e proporciona as seguintes vantagens:
- Adição da função [Picture Effect] [Efeito de imagem].
- Adição da função [Peaking] no modo de focagem manual.
Vantagens oferecidas pelo programa de actualização anterior (Ver.03) e incluídas na versão 04.
- Adição da função que permite personalizar teclas de função.
Agora já é possível personalizar as funções das duas teclas de função do painel posterior da câmara. - Adição da função [Menu start] [Menu Iniciar].
Se seleccionar 'Menu', pode agora aceder ao ecrã do menu principal ou ao último parâmetro definido. - Melhoria da operabilidade da função [MF Assist] [Assistência FM]
Agora já é possível ver parte de uma imagem ampliada no ecrã durante um período de tempo seleccionável pelo utilizador com a câmara no modo de Assistência FM (Focagem manual). O funcionamento do modo de Assistência FM também foi melhorado. - Melhoria da operabilidade na selecção de opções de menu
O funcionamento dos menus foi simplificado. - Manutenção da definição de abertura no modo de gravação de filmes
Agora já é possível filmar imagens de vídeo em HD mantendo uma definição de abertura constante. - Suporte da função de focagem automática em objectivas de montagem tipo A
Nota importante: actualize o adaptador de montagem LA-EA1 se utilizar objectivas α na sua câmara com o adaptador de montagem LA-EA1.
As objectivas SAM e SSM indicadas a seguir são suportadas*:- Objectivas SAM
- DT18-55 mm F3.5-5.6 SAM [SAL1855]
- 28-75 mm F2.8 SAM [SAL2875]
- DT55-200 mm F4-5.6 SAM [SAL55200-2]
- DT30 mm F2.8 Macro SAM [SAL30M28]
- DT35 mm F1.8 SAM [SAL35F18]
- DT50 mm F1.8 SAM [SAL50F18]
- 85 mm F2.8 SAM [SAL85F28]
- Objectivas SSM
- Vario-Sonnar T* 16-35 mm F2.8 ZA SSM [SAL1635Z]
- Vario-Sonnar T* 24-70 mm F2.8 ZA SSM [SAL2470Z]
- Distagon T* 24 mm F2 ZA SSM [SAL24F20G]
- 70-200 mm F2.8 G [SAL70200G]
- 70-300 mm F4.5-5.6 G SSM [SAL70300G]
- 70-400 mm F4-5.6 G SSM [SAL70400G]
- 300 mm F2.8 G [SAL300F28G]
- Objectivas SAM
- Ampliação da imagem com a opção [Release w/o Lens] [Libertar s/ objectiva] definida como [Enable] [Activar]
Vantagens oferecidas pelo programa de actualização anterior (Ver.02) e incluídas na versão 04.
- A função Sweep Panorama 3D foi adicionada;
- Melhoria da fotografia/filmagem com a função Sweep Panorama 2D 'normal';
- Diminuição do consumo de carga da bateria quando a câmara está desligada;
- Arranque mais rápido em condições de pouca luz.
Sistemas operativos compatíveis
- Windows XP* SP3
- Windows Vista** SP2
- Windows 7
Notas:
- * As edições de 64 bits e Starter não são suportadas.
- ** A edição Starter não é suportada.
- Hardware do computador
- Espaço no disco rígido: 200 MB ou mais
- RAM: 512 MB ou mais
- Fonte de alimentação da câmara
- Bateria recarregável NP-FW50 totalmente carregada
ou
transformador de CA AC-PW20 (vendido em separado)
Nota: a actualização apenas pode ser efectuada quando o nível de bateria restante equivale a(três marcas) ou mais. Recomendamos que utilize uma bateria totalmente carregada ou o transformador de CA AC-PW20 (vendido em separado).
- Cabo USB fornecido com a câmara
Nota: a funcionalidade de actualização não é garantida com qualquer outro cabo USB.
Notas importantes:
- Quando efectuar a actualização do firmware, utilize uma bateria recarregável NP-FW50 totalmente carregada ou o transformador de CA AC-PW20 (vendido em separado).
- Não retire a bateria ou o transformador de CA durante a actualização. Caso contrário, pode deixar de conseguir utilizar a câmara devido à interrupção súbita da alimentação.
Passo 1: transferir o programa de actualização do firmware
- Assegure-se de que iniciou a sessão como administrador do computador.
- Depois de ler a exclusão de responsabilidade, clique no botão [Download] [Transferir] abaixo.
- A transferência do ficheiro [NEX-3V4_Update1104a.exe] (61,6 MB (64 685 448 bytes)) começa.
- Guarde o ficheiro no ambiente de trabalho do computador (recomendado).
Passo 2: actualizar o firmware da sua câmara
- Feche todos os programas actualmente em execução no computador.
- Clique duas vezes no ficheiro [NEX-3V4_Update1104a.exe] que transferiu para iniciar o Firmware Updater (programa de actualização do firmware).
Aparece a janela do Firmware Updater. - Siga as instruções na janela do Firmware Updater, seleccione Menu--> Setup [Configuração]--> USB Connection [Ligação USB] na câmara, e verifique se a opção Mass Storage [Armazenamento em massa] está seleccionada.
Se existir outro modo seleccionado, que não o Mass Storage [Armazenamento em massa] , seleccione Mass Storage [Armazenamento em massa] . - Ligue a câmara ao computador utilizando o cabo USB fornecido.
Nota: quando a câmara está ligada ao computador, o ecrã LCD da câmara desliga-se. Avance para o passo seguinte. - Confirme que o ícone "Remover o hardware com segurança" é apresentado no tabuleiro de tarefas no canto inferior direito do ecrã do computador.
- Após esta confirmação, clique em Next [Seguinte] na janela do Firmware Updater. A figura 1 aparece na janela do Firmware Updater, e a figura 2 aparece no ecrã LCD da câmara.
Nota: a partir deste momento, nunca desligue a câmara até a actualização do firmware estar concluída.
Figura 1
Figura 2 - Após confirmar os ecrãs das figuras 1 e 2, clique em Next [Seguinte] . A versão actual e a versão após a actualização aparecem na secção inferior esquerda do ecrã. (Figura 3)
- Após confirmar o ecrã da figura 3, clique em Next [Seguinte] .
Se o ecrã da figura 4 aparecer, a actualização não é necessária. Siga as instruções da mensagem, interrompa a ligação USB e clique em Finish [Concluir] . Desligue a câmara, retire a bateria e/ou o transformador de CA, insira novamente a bateria ou ligue novamente o transformador de CA e ligue a câmara.
Figura 3
Figura 4 - Clique no ícone "Remover o hardware com segurança" no tabuleiro de tarefas no canto inferior direito do ecrã do computador para interromper a ligação USB, tal como indicado na figura 5.
Nota: mantenha o cabo USB ligado, mesmo após interromper a ligação USB no computador com a operação descrita acima.
Figura 5 - Prima o centro da roda de controlo para reiniciar a câmara.
Nota: o ecrã desliga-se se premir a tecla de função. Avance para o passo seguinte. - Após reiniciar, a nova ligação da câmara é verificada, e o ecrã da figura 6 aparece.
- Clique em Run [Executar] para iniciar a actualização. A barra de progresso aparece durante a actualização (aproximadamente 3 minutos).
Nota: nunca desligue a câmara, nem desligue o cabo USB durante a actualização.
Figura 6 - Quando a actualização estiver concluída, o ecrã da figura 7 aparece. Clique em Finish [Concluir] e desligue o cabo USB.
Figura 7 - Desligue a câmara, retire a bateria e/ou o transformador de CA, insira novamente a bateria ou ligue novamente o transformador de CA e ligue a câmara.
Passo 3: confirmar se a versão do firmware da sua câmara é a Ver.04.
Cumprimentos
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Obrigado pela informação.
Mas não querendo parecer chato continuo com umas dúvidas. Gostaria que me desses o link dos firmwares pois tenho que actualizar todos. só tenho a 1ª versão. É que segui a dica no youtube da sony, http://youtu.be/I_asX8jKwws, e este direccionam-me para este site http://esupport.sony.com/ e ao que parece é só para o continente americano. Já procurei aqui no site Portugues e não encontro.
Ou não há em Portugues?
Cumps
Paulo
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Caro Paulo,
Há página em português...:smileywink:
Tem aqui, com as actualizações disponíveis...confirme se é a NEX-3 e não a NEX-C3 que dispõe...
Não instale as actualizações para Mac...
Comece as instalações de baixo para cima (ver data)...
Quando entrar na página seguinte para efectuar o download, quase no final da página, tem de clicar no quadrado que se encontra do lado esquerdo..."Li a renúncia de responsabilidade..."
Cumprimentos
