Can I use the HDR-PJ780 Camcorder as a webcam?
R.Black
2 ODPOW. 2
Anonymous
Nie dotyczy
IamNic
Hi @R.Black,
it has a HDMI out, so I assume you could.
Best to check once with a TV or Monitor, whether this HDMI output is or can be set up to be "clean" (without any UI overlayed). If that is the case, you can go ahead and purchase any "HDMI capture card" of your choice (a small USB-Stick with a HDMI port in the back).
I suggest the ELGATO Camlink 4K to be used. Then you can use the camera as webcam in any software of your choice.
- Nic
