DCR-DVD 200E Digital video recorder
MSB444
New
Hi I had the above video recorder and it was stolen - unfortunately I have loads of disks that have never been 'finalised' (used to always play them back through the video recorder). How can I finalise them? Can I do it on any Sony DVD recorder? For example could I do it on a DVD 101 as this is considerably cheaper than a 200E.
Thanks
MSB
1 REPLY 1
Joe_Dohn
Specialist
If the disks are inter-compatible, I don't see why not. You'll just need to double check that they are and go from there.
