DCR-DVD203E has a small USB Socket: what is it used for?
BudProd
New
It may be a Micro-B socket but the USB Cable supplied with the Handicam does not plug into it.
1 REPLY 1
Pumpkin_Duke
Member
Hi,
As far as I know you can use the USB connector to transfer videos to you PC using picture motion browser.
The delivered cable should fit into this socket.
Cheers
PD
