I am using latest version of play memories, sony hdr-cx190, kingston 16gb class10 SDHC card...
camera is in mass storage, it says connected,
When I start playmemories, in upper left corner there is
i: PMHOME
J:
J: is memory card, i select that, i select videos for transfering and drag them to area, and on right side i press export, to put m2ts videos to card (videos are recorded with same camera) and I get:
The destination drive cannot be found.
Check that device is connected to computer and turned on, and try again.
Importing to computer works... also i can browse card in windows explorer...
REINSTALATION DOES NOT SOLVE PROBLEM
When I open my computer, J disc is write protected.. is it normal? can camera export videos to her memory card while shown as write protected in my computer?
