FDR-AX53 XAVC-S 4K - "jerkyness"
clarkerz
New
Hi,
I have just purchased a FDR-AX53 from Jessops Cardiff on the 1st April 2016.
I am having trouble with JerkyNess when using recording movies XAVC-S 4K at both 60 and 100 mb/s. The quality is stunning but the jerkyness makes the picture annoying to watch.
All HD recordings are perfect and faultless. I have put 5 different tests here on YouTube and I'd like your thoughts on why it is "jerky". It's as though there is some sort of video processing being applied but I cannot see where to switch it of it there is. I really don't want to have take the camera back for a refund so hope this is resolvable.
Test 1 - https://www.youtube.com/watch?v=yHW5oP1vHYQ
Thanks
Clarkerz
23 REPLIES 23
Jonnie1266
Contributor
@clarkerz
Hi,
I am expecting delivery of this camcorder on Wednesday so it is somewhat disheartening that there are issues with 4K already. I know that the older 4K models did not appear to process the footage quick enough which gave the appearance of 'jerkyness' during panning - see this thread https://community.sony.co.uk/t5/camcorders/fdr-ax-33-panning/td-p/2004676
This camera has an improved processor and fast intelligent AF so one would expect better results ?
Sadly I read this on page 139 of the user manual regarding frame rates:
Available frame rate settings
XAVC S 4K:
30p(*)/25p(**)
24p(*)
XAVC S HD:
60p(*)/50p(**)
30p(*)/25p(**)
24p(*)
AVCHD
60i(*)/50i(**)
60p(*)/50p(**)
24p(*)/25p(**)
Descriptions of menu items
60i(*)/50i(**):
This is an ordinary setting for recording AVCHD movies.
60p(*)/50p(**):
You can record movies with a data volume twice that of 60i(*) or 50i(**)/30p(*) or 25p(**) per
unit time. When you play a movie recorded with this setting on a TV, the TV must be
compatible with 60p(*) or 50p(**) movie playback and you have to set [HDMI Resolution] to
1080p.
30p(*):
It is recommended that you use a tripod when recording movies with this setting.
24p(*)/25p(**):
You can record movies which provide an atmosphere closer to that of film images with this
setting. It is recommended that you record movies with this setting using a tripod.
Please note the section in red, as the only frame rate for 4K available is 25p (for a UK model) it would appear Sony recommend using a tripod ? If I am right then this is not great. Sure, they have got full HD sorted but 4K seems a little more challenging.
Personally I hope you can recover the issue through the camera settings, the footage does look good. I have purchased two of the following - SanDisk Extreme PRO 64GB SDXC UHS-I/U3 Memory Cards up to 95MB/s - which is the least that the user manual recommends for 4K 100Mb/s
It might be worth switching off the dual record function, that is if you have it enabled during 4K recording ?
Please let us know if you sort this out - sorry I cannot help any further
Regards
If it ain't broke don't fix it
Jonnie1266
Contributor
@clarkerz
Hi,
Did you resolve the "jerkyness" issue ?
I have my AX53 now and I am very happy with the results. I must say that I updated the software here
before I first used it. This update would not have been available to you at the time you posted this thread.
I recorded at 4K XAVC S 60MB/s and played from the camera through the television, I think it is brilliant !
I have reviewed the camera on this and Amazon web site.
Regards
Gope57
Explorer
Jonnie, Which Memory Card do you use for your AX53?
So it works in 4K
Jonnie1266
Contributor
@Gope57
Hi,
Sorry for the late reply, I have had trouble getting my account working !
Here is a link to the memory card that I have used: SanDisk
Ljoms12345
Explorer
As long as it is 25 P you wont be able to resolve it.  I dont use 4K when i am moving/panning and the result is more than good enough for my eye:)
profile.country.HU.title
CSABA53
Explorer
Hi,
I'm very disapponinted in the AX53.
I was looking forward to this model because of the promising huge marketing.
AX53 focus/lock-on AF FUZZY (after updated 1.01 software)
https://youtu.be/RWwCcBYmZnI
AX53 JERKY movements in 4K despite strong SteadyShot
 https://youtu.be/LacwGaAFbPE
AX 53 while panning FUZZY and CHOPPY images.
https://youtu.be/uKpZl6rGWl8
These are only part of the BASIC DEFECTS... (To be continued)
Nobody can help because new repair software is not yet.
I'm a practised user working as a cameraman/director.
I worked for 3 years with the former SONY model HDR PJ740VR.
Csaba
Hungary
Jonnie1266
Contributor
@CSABA53
Hi,
I appreciate your work as a cameraman. I am in no way a professional but I think the AX53 is brilliant. I am sure if it is as bad as you say I would notice these issues also ? Just a thought but have you wondered if your camera is working properly ? It may have a fault ?
Regards
CSABA53
Explorer
Hi,
You saw the tests, didn't you?
Problems need correcting with a new software update!
Otherwise, this model WILL BE great.
The sooner SONY realize its error, the better.
Csaba
Hungary
LennonMac
Explorer
I have just learned that if you mount the FDR-AX53 on a Tripod you cant turn on the Boss system Stabilisation and if you zoom while on the Tripod the footage is very Shaky,so i cant use a Tripod.
