From camcorder to digital file, help.
Droqles
New
Hi, I have an old camcorder Sony Digital 8 DCR-TR7000E/TR7100E.
I want to digitalize my old tapes that are 8mm Hi8 HG.
I have bought a USB Video Capture Device so that I can transfer it to my pc, but whenever I play a video through my camcorder the screen keeps going blue or showing something wierd 50% of the time.
Any idea of how I can do to minimize dataloss?
Should I somehow try to clean/rinse the camera or should I get another camera to transfer from?
Hope you can help. :slight_smile:
1 REPLY 1
IamNic
The video grabber probably uses a component cable.
If you get a signal when connecting said cable to your TV, you should get a signal when you connect it to your grabber.
If that is not the case, then your video grabber is probably broken.
