NormanOd
New
Handycam drivers
Does PlayMemoriesHome contain the Windows 10 installation drivers for Handycam PCR-DV110E?.  If not, is there any way of getting an original installation disk or the files it contained?
6 REPLIES 6
Anonymous
Not applicable
Hi there,
I'll look into this, and a community member will get back to you.
Best wishes,
M
NormanOd
New
Thanks,
I had assumed that, having installed PlayMemoriesHome, all I had to do
was connect the camera USB cable, it's not proving to be that simple.
Regards,
Norman
The_Black_Rose
Specialist
Hi NormanOd,
I couldn't find the model number any where. Are you sure about it? When did you purchase this camera?
Cheers,
The_Black_Rose
NormanOd
New
This is not a new camera, it is one using miniDV tapes, which Is why I
am having problems locating software.
Norman
The_Black_Rose
Specialist
Hi NormanOd,
I don't think this camera will be compatible with Windows 10, to be honest. However, I have seen some articles about transferring content from DV tapes to a computer.
I'd recommend checking the below links:
https://www.sony.co.uk/electronics/support/cameras-camcorders/articles/00083654
https://www.sony.co.uk/electronics/support/cameras-camcorders-camcorders-and-video-cameras/articles/...
Cheers,
The_Black_Rose
Blencogo
This comes up frequently even though USB transfer support ended with Windows XP.
https://community.sony.co.uk/t5/camcorders/sony-trv250e-drivers/m-p/2620090#M5137
