HDR-CX625 stuck on loop when powering up
Clydesider
Explorer
My HDR-CX625 camcorder, not even four months old, will not turn on.  It just sticks on the "Handycam" opening screen, loops three times then turns itself off.  I have checked Sony for help and they won't even repair it, they just say things are "in-warranty exchange" and are not economic to repair.
Does anyone have any guidance on how to fix this?
12 REPLIES 12
Clydesider
Explorer
Hi,
Apologies for the delay in responding.
The shop I purchased the camera from have now agreed to replace it so I will have a working camera from tomorrow.  However, I can confirm that there is no way to externally power the camera without a battery attached.
This is the second CX625 camera I have had and both have died with the exact same issue.  I am hoping this third one on the way does not do the same.  I have no idea what the problem is or what the cause of it is so it is impossible to try and avoid it somehow.
Thanks again for your assistance.
airandsteam
Explorer
I also have the same problem has anyone come up with an answer ?
airandsteam
HannahEd01
Hi,
Try the following:
- Disconnect the power source, attach the power source again after about 1 minute, and turn this product on.
-Initialize if you can get the menu:
https://helpguide.sony.net/cam/1610/v1/en/contents/TP0000933344.html
