I recently purchased the HDR-PJ810E and so far I am quite happy. The only issue I have is when using the projector to play back as the video gets choppy. I have tried various things, like using the internal memory, different SD cards playing back in MP4 mode. However, I always have a choppy video when playing it back through the projector. Anyone had this problem with the built in projector...ad any tips??
Solved! Go to Solution.
By accident I found the reason why the playback was choppy through the projector.
It is not mentioned anywhere in the litrature and I couldn't find any mention of it on any forums anywhere, or from support. The camera should be set on a stable surface and be kept motionless, if you try holding the camcorder while projecting (like it shows you on their demo video) the playback becomes choppy.
So a very simple solution:smileyhappy:
I have only had this camcorder for a few days so I am still trying all the features out. So far I am very happy with the results except for the still image quality which I sort of expected was going to be poor, however I did not expect the stills would be as poor as they are where most phone cameras produce far better stills.
