HDR-XR520V no possible delete pictures from Play Memories Home
profile.country.ES.title
djlutz
Explorer
Hi,
I can connect to my HDR-XR520V from PlayMemories Home perfctly.
everything works weel but not the posibility of DELETING PICTURES from the camera.
Neither from a MemoryStickPro inserted nor from the HardDisk.
Both are "write enabled".
Any help would be appreciatyed.
Software is up to date.
1 REPLY 1
ClarissaW
Member
Hello djlutz
According to the manual here, you should be able to:
"If you click [Settings] and put a check in the [Delete imported media files from the device or media] checkbox, videos and photos will be deleted from your camera after they have been imported to your computer."
Does this help at all?
Kind Regards,
Clarissa
