How do I download motion picture browser for iPad
SOLVED
profile.country.en_GB.title
Salesguru
Visitor
How do I download motion picture browser to iPad
1 ACCEPTED SOLUTION
Accepted Solutions
Blencogo
You can only download Applications available through the iTunes Apps Store on your iPad.  You cannot install any other software even if it is Mac compatible.
However, you can sync and load video and photos via the iTunes program.
:wink:
2 REPLIES 2
Blencogo
:wink:
Salesguru
Visitor
Thanks I will give it a try
