How to convert HD 2080/25P FX ????
mihaicocrea
New
Hello
I have a Sony HDR-AX2000E and I made a recording with REC format HD 1080/25P FX, when I want to see the recording in the camera screen, I can hear the sound but the image is missing (I have some vertical coloured lines filling the screen). Are there any apps that I can use in order to see the video after I have downloaded in the computer??
1 REPLY 1
IamNic
Hello @mihaicocrea,
any modern media player should play 1080p/25fps video files.
I prefer VLC media player.
If you can't play back the file in camera, it sounds like the file is corrupted though.
- Nic
