how to transfer video from dcr-trv245e camcorder to PC
SOLVED
profile.country.en_GB.title
Ellie12
Visitor
hi,
Where do I download software needed to download and edit video recorded on SONY dcr-trv245e camcorder?
Thanks in advance for your help.
1 ACCEPTED SOLUTION
Accepted Solutions
blaireau_photo
Visitor
Hello ellie12 :slight_smile:
Looking at the downloading first of all, a lot of the major video editing packages include the facility to 'capture' video directly from the camera itself. They vary in price but even the free option offered by Microsoft, Windows Live Movie Maker 2011, allows the user to capture video onto their PC hard drive and then edit.
The biggest issue that you will face is if you are using Windows 7 as opposed to Windows XP on your computer. For this camcorder, video capture over USB is significantly easier when using Windows XP but if you are using Windows 7, you may find it easier to use Firewire for capturing your video and if your computer doesn't have a Firewire socket available, you may need to purchase a Firewire to USB adapter or a seperate internal card for this purpose.
Thanks,
Simon
2 REPLIES 2
blaireau_photo
Visitor
Thanks,
Simon
moiranorway
Explorer
Hi ,
I have fire wire connection on  the computer but I cannot find a fire wire socket on the camera
