johnahy
New
memoery card
I have a Sony HDR-CX115E camcorder
Can I use aSDCX  SD  10HS1 64GB memory card
If not what is best
1 REPLY 1
Blencogo
Hi johnahy and welcome.
Do you mean SDXC?
You can use SDHC or SDXC up to 64GB (Speed Class 4 or more).
A word of warning. SDXC cards use the exFAT format which may not be supported by your computer. Check first that your connecting equipment supports this format.
:wink:
