.RSV File
LawJim
.RSV File
When I open my folder to where I downloaded my XQD card to I noticed that I had 4 files attached to a clip that I filmed. .
MXF file with 0 kb
.SRV File with 2,080,768 kb
.SLI File with 0 Kb
.BIM File with 0 Kb
I cannot open the .RSV file that has the data on it.
Any help greatly appreciated
3 ODPOW. 3
IamNic
Hello @LawJim,
since your camcorder uses a XQD card it sounds like you use a Pro-Camcorder.
Therefore please get in contact with Sonys pro support.
Which camera model do you use?
- Nic
LawJim
I use the Sony PXW-X160
IamNic
Hello @LawJim,
just as I suspected - please get in touch with Sonys Pro support, since you are elligable to it: https://pro.sony/en_GB/support-services
- Nic
