Ever since i got my AX53 back in November last year, I’ve always noted something that seems a little weird. When I shake the camcorder from side to side when it’s turned off, it makes a rattling noise. I’m 100% sure that it’s the lens making the sound, because I can feel slight bumps from the front-part of the camera when I shake it. Is it normal that the lens moves when the camera is turned off? If you have a Sony FDR AX53, I would really appreciate if you could shake the camcorder when it’s turned off. And if it does move & make noise, let me know!
/Martin
Solved! Go to Solution.
I believe, the documentation that came with the camera says that this is normal.
Although I don't think it's normal to shake a camera, I thought you're supposed to hold them steady 😉
Yes. It like shakes a split second when I turn off the camera (flip the screen) letting me know that the lens is fixated in the middle, which means that the stabilization is turned off. Even if I turn off the stabilization, the same thing happenes.
