Sony HDR CX130e
profile.country.en_GB.title
powerslave16v
Visitor
Sony HDR CX130e
Hello
Could anyone tell me is this camcorder which is a uk version 1920x1080?
Reason why i'm asking this is when i upload files onto you tube and play them back there never is a 1080 option just the 720 one.
And comparing the 1080 files with 720 they look a lot better.
I upload onto a imac and edit in imove,then upload onto you tube if that helps anyone.
Also there is no 1080 option in the cams menu,i just set it for the highest quality,but i think its just records at 720.
Can anyone advise please..
Ian
1 REPLY 1
brrobin19
Explorer
On Utube the highest resolution is 720, you cannot get 1080. Sorry.
