ZONY HDV Z1U CAMCORDER OUTPUT !
gascoyneone
New
I now cannot use my Z1U  because I upgraded to a iMac and the computer  ports no longer take the old firewire cable.
I bought an adaptor to USB 3  ports but this was useless. Is this camera now redundant or can it the material be outputted somehow to USB3 ? Or perhaps another output ?
1 REPLY 1
Peter_S.
Genius
Hi,
You would need a Firewire adaptor to use the camcorder with your iMac.
Probably the one you've obtained doesn't work as it should.
Cheers
Peter
