Cybershot HX1 battery (NP-FV50?)
SOLVED
profile.country.IT.title
StevOne58
New
Hello, I intend purchasing a spare battery for my Cybershot HX1 (NP-FH50), a storekeepr proposed I buy an  NP-FV50 stating that its the new more powerful replacement for the FH50. Can anyone confirm this? I'd hate buying a €70 battery that could damage the cahrger or, worse still, the camera.
Thx, Steve
:dizzy:
Problem solved with help of another support forum: FYI for anyone with doubts, the answer is NO! the FV50 will not fit into the battery slot of a cybershot HX1
Messaggio modificato da StevOne58
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.en_GB.title
StartTheCar
Contributor
Thanks for coming back and confirming the answer  StevOne58, very much appreciated.
Just so I can mark this thread as answered:
The NPFV50 is not compatible with the DSC-HX1 camera.
Regards
Lee
1 REPLY 1
StartTheCar
Contributor
Regards
Lee
