File error downloads??
SOLVED
profile.country.en_GB.title
Dermino
Visitor
I am trying to download pictures, but when I reach a certain image the download stops. When I checked the camera it has the message 'file error' accross the picture which is stopping the download. How do I overcome this? I have tried deleting the image, but I can not.
1 ACCEPTED SOLUTION
Accepted Solutions
Blencogo
Have you tried copying the pictures from the camera to your hard drive using Windows Explorer? Right-click on Start and select Explorer and your camera should appear as an additional Drive.
With that you can select which pictures, or groups of pictures, to copy and you can just omit the offending image.
:thinking:
1 REPLY 1
Blencogo
:thinking:
