Random 'Illustration high' pictures.
jfriz22
I have a DSC-HX60V camera. While on holiday I took some 200 photos but 12 of the pictures were found to be in 'Illustration high' picture effect mode even though picture effects were permanently set to 'off' in the menu settings.
They occurred consecutively in two separate groups on two different days.
I am concerned that this could happen again if taking important photos.DSC03517.JPG
1 ODPOWIEDŹ 1
Elodin
Moderator
Hey, make sure that your camera is running on the latest software version from here: http://bit.do/fVb8P, if your camera is running on the latest software version, you need to perform a setting reset, you can do that from this link: http://bit.do/fVb8M. I hope this helps.
