Sony DSC-W310 or W320
SOLVED
profile.country.hr_BA.title
djukak
Visitor
I'm buying for home use only
Dilemma is between Sony W310 i W320.
http://www.sony.ba/product/dsc-w-series/dsc-w310
http://www.sony.ba/product/dsc-w-series/dsc-w320
Main difference is: W310 has 12.1 MP and Sony lens.  W320 14.1 MP and Carl Zeiss lens.
Question is: Is Carl Zeiss lens better? Difference in price is 25 euros. Are pics better, is it noticeably...
Is it worth to buy Carl Zeiss?
Thanks in advance
1 ACCEPTED SOLUTION
Accepted Solutions
Blencogo
HI djukak,
There are other small advantages to the W320: -
1. It is a more attractive design and is smaller and lighter.
2. It has a better battery life - 220/240 shots.
3. It has a better 14.1 megapixel sensor.
4. It has a wider angle lens 28mm/26mm.
5. It has a superior Carl Zeiss lens.
Is it worth an extra €25?
This has to be down to you.  Try and handle them because the W320 is lighter, slimmer and smaller in all three directions and, for me, a more modern attractive style.  I doubt if you will notice the other advantages listed above and there is no killer improvement in the W320 that makes it that much better.  Everything is a little better but the two models cover a price range in the market.
Your decision but I think I know which one I would buy if I could afford the extra.
:wink:
2 REPLIES 2
Blencogo
HI djukak,
:wink:
profile.country.en_GB.title
Tush65
Visitor
Hi which camera did you end up buying. I have got the same dilemma now. Have been advised on buying Carl Zeiss lens but Im sure Sony have looked into this thorougly but I dont know which is best.
  I am looking at cybershot  dsc w520 and w530. The 520 has sony lens and is 5x optical, the w530 has carl zeiss and is 4x optical .
Any help will be much appreciated.
Thanks
