I forgot my pin password and how to reset
qhairulvale
hi, i want to ask how to reset xperia e dual , without open menu , please help me admin and other user !! i cant open my homescreen how to reset or bypass or anything . thanks , i hope please reply fast Thinking_Face
20 ODPOW. 20
eddyeddy
I have the same issue, using PC Companion I get a message saying I need to enter my PIN which is the whole point, I don't know it.
te4
Please help forgotten pattern need my phone...
mcgiltp
this is my childs phone she forgot her pin code.sony e5
lipreader
Help cannot reboot my phone smileyshocked: I have tried the compaion but it keeps asking for pin and wont let you do anything else till you put pin in, anybody having same problem.::smileyd_oh: I need to get phone up and running again
Ilegalfall
Hey there I also have a Sony E5 and I've forgotten my details and of the Google and I tried factory resetting but I'm stuck, have you found a solution that worked or that I can try.
ruban1
sir i am using sony xperia mobil c2 ..i for got my pass word ..but in my in my sms the pass word is there ..cant able bo go in side .and read my masage ..help
baldylocks1
how can i remove the pin number for my experia e5
Uliwooly
@baldylocks
you have to access the settings > security > pin > enter the pin > then you can select none
baldylocks1
Thanks a lot , now sorted
fixasony
Did you manage to unlock your xperia c1505  . Iam stuck with same problem
