hi, i want to ask how to reset xperia e dual , without open menu , please help me admin and other user !! i cant open my homescreen how to reset or bypass or anything . thanks , i hope please reply fast
Try this:
To repair the phone software
1. Install PC Companion on a Windows PC from Support
2. Turn on the phone, and connect it to the PC using a USB cable.
3. In PC Companion, under Support Zone and click Start.
4. Under Phone Software Update, click Start.
5. Click repair phone.
6. Follow the on-screen instructions.
What are your thoughts about this forum? Let us know by doing this short survey.
Try this:
Hello sam , i have do what like you said but this problem coming -
Please help me , i need to use my phone .
Hello sam , i have reset or format my phone using software update from sony . Thanks
what intructions did he give you,i have the same problem
how long is this process meant to take?
Thanks for the method sir
same
i also having the same problem and now im following these steps its saying preparing the computer for software update and loading......hope it works... I REMEMBER THE PASSWORD BUT I'VE PUT A SMILEE AS MY PASSWORD AND THERE WAS NO SMILEE OPTION INTHE UNLOCK SCREEN SO IM STUCK.....
