I didn't Used The lock screen For 6 months And now when I lock my screen with pattern! After 15-20 seconds It directly Goes into Home screen!! Ignoring the pattern I kept!! First I thought maybe Any third party app restricted lockscreen but Even when I reboot to safe Mode the problem Persist!, I tried Restarting! Updating and Resetting!! But the problem Still persist
Hi @KJayavishnu,
I would recommend that you remove and re-add your pattern lock.
If you are still experiencing the same behavior I'd recommend that you perform a software repair using Xperia Companion.
Let me know how it goes.
