Vibration notification E5 F3311
matik
Visitor
How to disable vibration on E5 F3311
Как отключить вибрацию на E5 F3311
3 REPLIES 3
Uliwooly
@matik
Are you trying to disable vibrate notification on ALL notifications or an specific app?
matik
Visitor
All vibration
Всю вибрацию
Uliwooly
@matik
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
set the phone to do not disturb mode
OR
open each app that you are getting notifications from > settings > notification > disable vibrate notification > repeat as needed
