Xperia E5 Cannot reset
profile.country.NL.title
alienatarea51
I bought this phone , but it is locked with a pattern.The seller forgot this , so i try to do a reset via Volume Down+Power Off.This does not work : the phone keeps restarting .What can i do ?
Thanks
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Jonas
Guru
Hi again @alienatarea51!
Start the Xperia Companion program without having the device connected to your computer and have it turned off > press on "Software repair" > check the little box in the bottom right corner where it says "My device can't be powered on or is a Smartwatch 3" > Next > proceed with the on screen instructions.
Good luck! Slightly_smiling_Face
5 ODPOW. 5
Jonas
Guru
Hi @alienatarea51, welcome to our forum!
On Xperia devices, you can not reset the device using a key combination so in your case, you will need to perform a software repair using Xperia Companion to get rid of the screen lock on the device.
The software repair will reinstall the software in the device and in the same process, remove the screen lock. Keep in mind that the device has an inbuilt theft protection, so if there is a Google account on the device when you do the software repair, this account will need to be used to verify the ownership after the repair has been completed.
I hope that helps! Slightly_smiling_Face
alienatarea51
Hi
that is the problem : to use the Xperia Companion software , i have to set the device to MTP mode.
But with a locked phone , this is not possible.
Jonas
Guru
alienatarea51
It worked !
Thanks a million...
Jonas
Guru
@alienatarea51, you're welcome and I should have made it more clear in my first reply (or to update the software repair guide so it mentions that the instructions in 2B should be used when the screen lock can't be remembered as well).
Take care and have a nice weekend! Slightly_smiling_Face
