Reader PRS-350 (Reader Libary will not open)
profile.country.en_GB.title
lintrant
I have received a Sony PRS-350 as a Christmas Present, after following instructions to install the Reader Libary, a Icon is now on my desk top but I am unanle to open this?
Any help would be appreciated.
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
SteveF48
Remove it from your PC, it's useless. No on second thoughts, just ignore it.
Do a Google search for 'Calibre ebook management' and use that instead.
You'll also need Adobe Digital Editions if you want to read ebooks that you've borrowed, or bought.
Both of the above are free software. By the way Adobe Digital Editions didn't work for me until I did a hard reset. The instructions are in another post in this forum, they are for a PRS-650, but work the same on my PRS-350.
N.B. I don't put links in posts, because I don't trust links other people post. They are too easily spoofed, or forged and go out of date.
5 ODPOW. 5
SteveF48
lintrant
Thank you for your help, I now have ebooks on my reader. I was just about to throw it in the dustbin. Big Thankyou
carpetmojo
sorry, but what's a "hard reset" ?
carpetmojo
oops - always read other posts before asking ! Found it, but is there then a "soft" reset ?
pesimps27
I have just upgraded my reader library following a pop up. Consequence: what previously worked perfectly now wont open any of the books, it just says they have been deleted renamed or moved. (If so where to??)
