Sony reader prs-t1
SOLVED
profile.country.nl_NL.title
Bhaggie52
Visitor
Sony reader prs-t1
my pc doesn't recognize my sony reader. how to fix
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.en_GB.title
carpetmojo
Member
After you plug into PC, the initial process should kick in - follow screen prompts.
You will need Reader 4 Pc, and Adobe digital editions , which will "authorize" your reader.
Good luck...
1 REPLY 1
carpetmojo
Member
Good luck...
